arturo owen
10 points
Posted on - 03/30/2012
I need to uninstall a game fallout and when I attempt to do so there has been an error sas runtime error which I cannot figure out why. I need someone to inform me about how to solve the error or how to uninstall the game anyway. I am looking forward to receiving answer as soon as possible. Someone kindly provide me with the solution quickly.
Arturo Owen
Uninstall problem with pc game – file does not exist
Hi Arturo Owen,
    Well, being unable to uninstall files such as these can really get so much annoying especially when it covers up so much space in your hard drive. It can also destroy the file management in your hard disk especially when you are unable to uninstall files you do not use or you do not need. Well, whatever is causing it is probably because of a corruption of an uninstaller file in Fallout. Rather than uninstalling it directly through Windows, I suggest you use an application to delete. I recommend using CCleaner. It is able to delete and uninstall files. Not only that but it is able to optimize your system, and clean your registry.
Maybe you have an expansion in your Fallout or is there? Delete the expansion first, then delete fallout next.
The least possible way would be deleting the folder of Fallout directly.
Hope any of those help.
>>Mathew Joni<<
