Uninstall Programs In Windows 8
Hi
How to uninstall programs in Window 8?
Since I was a Windows XP user, it's pretty difficult to cope up with Windows 8. Everything seems so jumbled here…so having a hard time to understand the new system.
I'm not able to find out the uninstallation option here. Where can I find it?
Thanks in advance.
Answered By 10 points N/A #180944
Its very simple to uninstall program in windows 8.It’s almost same like how we used to do it in earlier version.
Steps:
1.Swipe to the right of your screen.
2. Click on search and then write the program name whichever you want to uninstall.
3. Select on the icon and right click, you will get an option to uninstall in the bottom of the screen.
4. Click on uninstall and you will be taken to control panel>programs and features.
5. Right click on the program you want to uninstall.
6. Click on Finish after uninstalling.
Answered By 590495 points N/A #180945
Uninstalling programs on Microsoft Windows 8 is very basic. The interface may be different but the process is the same. The new appearance of the Windows 8 desktop may confuse you but it is all the same. Here’s how to uninstall or remove a program on Microsoft Windows 8. First, swipe in from the right edge of the screen then tap Search.
On the other hand, if you are using a mouse, direct your mouse pointer to the upper-right corner of the screen, move the mouse pointer down, and then click Search. In the search box, type without quotes “control panel” then click Control Panel. Under “View by”, select Large Icons, and then click “Programs and features”. Click to select the program you want to uninstall and then click Uninstall.
Next, follow the succeeding instructions on the screen to complete the uninstallation. And that’s it. Your program on Windows 8 has been uninstalled.
