Hi guys,
Is there a quick office remover? I got a nokia c5 03 series and a friend of mine installed something like quick office. How can I safely remove the quickoffice application in my nokia c5 03 mobile phone device? I hope you can share some important idea regarding this issue.
Expecting some help, thank you.
Uninstall Quick Office Application on Nokia C5-03
Hi Ericsson Eric,
Firstly check for which drive the application has installed in whether C or E.
If the app was installed in C and you are not able to uninstall from the phone, then first install the Nokia PC Suite for your phone (the cd comes with the phone) to your pc if its not already installed.
Connect your phone to the PC Suite using any means( Cable, Bluetooth, etc).Â
Navigate to the installed apps. Select the app that you want to uninstall. Once selected, the Suite gives you an option to uninstall/delete the app safely.
Powel Jedei
