Uninstall Windows 8 Developer Preview
Does someone here know how to remove Windows 8 Developer Preview?
I need a step-by-step guide to do this.
Hi Joem dela paz!
Here is the step by step guide as you requested.
I hope this has helped you.
Regards.
Hi there!
You were asking how to uninstall your Windows 8 Developer Preview Program. Please try this, First you go to your Home button, go to your control panel and you can see lists of settings including a program with a significant “uninstall a program” under it. Then you go to programs and features and then you must choose and or find your program that is.
Windows 8 developer preview” and a pop-up box will come out saying: Are you sure you want to uninstall Windows 8 Developer program?
Then of course you click yes, and Windows installer will start removing your program in a few minutes, then you can restart your computer after and voila!
Your program is removed.
Hope this helped.
I followed your steps, Galarpe Miloni.
Thank you very much. I run msconfig > System Configuration > Boot tab > Select windows developer preview > delete > apply > ok,
Then formatted the partition.
Thanks for your help.
Notifications
