Uninstallation error with pc game – error occurred during process
I have gears of war pc game installed in my pc, and it does not run very well.
I want to delete it, but there has been an error message which does not allow the process to follow or continue. I have already tried to remove the files manually but it seems that it is only a waste of time, and it may have been a problem with directory.
Kindly someone help me with it.
Jayson Mars
Error:
Jnhandled Exception
Error Number:0x80040702 Description:Failed to load DLL:GameuxInstallHelper
Setup will now terminate.
Answered By 590495 points N/A #108303
If Gears of War does not seem to work properly on your computer, it is possible that your system does not meet the game’s minimum system requirements.
If your machine is below the required specifications, the game will perform very poorly and will sometimes exhibit different kinds of errors.
You can install Gears of War on a computer that runs on Windows XP, or Windows Vista. Windows 7 is not included but you can try it since it’s a much higher Windows version.
Just uninstall it if it doesn’t work. It requires at least a Pentium 4 processor with 2.4 GHz speed or much faster. The game requires a minimum of 1 GB available RAM on your CPU.
Don’t delete the game’s installation folder or else you will not be able to uninstall it. Try removing it using the Add or Remove Programs applet in Control Panel.
But if it fails, try downloading and installing Revo Uninstaller Pro at https://www.revouninstaller.com/. It is a tool for uninstalling hard to remove programs. Try using it to remove your game from your computer.
