Hey guys,
I am having a few problems with the Rising PC Doctor uninstallation. It is still running in the background after I uninstall it and there are leftover pieces of software all over the place that I can't delete. Can anyone off a solution to my problem?
Any help would be great.
Uninstalled rising pc doctor but still having issues
Hello Tony
I will try to give you the best solution, in order for you to completely uninstall Rising PC Doctor.
Go to Control Panel, Uninstall a program, and in that list, locate PC Doctor and click on Uninstall.
Go to Start, All Programs and locate PC Doctor. If it has an uninstaller, click on it. If you do not find it means the program was successfully removed.
Click Start, and in the Search box, type regedit. Access it, and there find and delete every registry entries of the program in:
HKEY_CURRENT_USERSoftware
HKEY_LOCAL_MACHINESoftware
HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionRuneg ui
Also find and delete every file of the program from system folders.
C:Program Files C:Document and SettingsAll UsersApplication Data and C:Documents and Settings%USER%Application Data
I hope you will find this information useful.
Randolph
Try uninstalling it with Revo. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select Rising PC Doctor among the applications and click “Uninstall”. Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then restart the computer. If Rising PC Doctor failed to uninstall because of missing files as a result of your first uninstallation, install the program again. Download Rising PC Doctor and install it. Once installed, uninstall it again with Revo.
