Uninstalling of alot toolbar old
I installed alot toolbar old which I got as freeware from the net, I uninstalled it from control panel, and it displayed that it got uninstalled, but it seems to be still in the Firefox. I want to uninstall the same from Firefox without uninstalling Firefox, Please Help me on how to do it.
Answered By 50 points N/A #166735
Hello, Jhon
Hope you  are fine. Yes it may be in the Firefox but you can remove easily. as you said you uninstalled that the program, so you need to use a PC cleaner to remove it. There are many PC cleaner tools in the market. just install it and run PC cleaner and then click "Registry" located in the left panel. Now click "Scan for issues."  Then click "Fix selected issues." This will help you remove it.
 Hope you will get your answer.
