Uninstalling factory installed app in android Devices.
What are the various ways and techniques in uninstalling factory install apps in Android devices except rooting? My Acer Iconia One 7 Tablet comes with some apps that are not in my liking. I tried to uninstall them, but the only options I see is only force stop the apps which may resume later without my request. How do I get rid of these apps without rooting the tablet?
Answered By 0 points N/A #191399
Hi Jose,
It is unfortunate that you cannot remove, delete, or uninstall pre-loaded app from your Acer Iconia One 7 Tablet as of the moment. However, there are some third party apps that promises to provide task as what you have wanted but I could not recommend it without trying it first myself. What we could probably do at this time is to raise that feature to the manufacturer so that when the update or upgrade comes out, they would have probably included the feature of pre-loaded app removal.
