Uninstalling Folder Lock Error 0x801F0004
I have used a program called Folder Lock and I'm having troubles uninstalling it. It gives me Error 0x801F0004 when I try to remove it from Control Panel > Add or Remove Programs. I also can’t delete the .flk files associated with it. How can I totally remove it from my computer?
Thanks for your help in advance.
Answered By 0 points N/A #159785
Hi Jettphoenixx, I searched a solution that may help you solve your problem.
This Folder lock program cannot be uninstalled by just removing it from the control panel.
So all you have to do is to follow these simple steps.
1. First you have to do is to open the program,
2. Then click on settings.
3. At the settings click on Program security and you will see a box that says put master password just uncheck it.
Clicking uninstall will require Master password so you have to input it.
When happen to forget that master password. You need to change the password security settings.
Click on Password Security tab and uncheck the Uninstall requires a master password.
After doing those steps you can now delete it from the control panel.
Hope this information helps.
