Uninstalling ‘MetaFrame Presentation Server’ – Error 29501
Asked By 100 points N/A Posted on -
While uninstalling ‘MetaFrame Presentation Server’ from a server which is in my farm, I got the following error message.
Error 29501. Setup has determined that Application Isolation Environments exist on this server.
Remove all of these before continuing with uninstallation.
My server’s address is enclosed in ‘an isolation environment definition’. I can’t guess what the problem is.
Can you?
Please help ASAP.
Error 29501. Setup has determined that Application Isolation Environments exist on this server. Remove all of these before continuing with uninstallation.
Best Answer by parker_carter
Answered By 0 points N/A #133890
Hi Hollis!
You will need to force uninstalling MetaFrame Presentation Server by adding“CTX_MF_FORCE_SUBSYSTEM_UNINSTALL” and set the value to “YES”. Run your command prompt to add it. Here is the syntax of the code: “msiexec /x mps.msi /L*v c:output.log CTX_MF_FORCE_SUBSYSTEM_UNINSTALL=YES”.
Before attempting to uninstall Citrix Presentation Server, you must remove all isolation environments. Also, if you do this on a server hosting the data store, it will delete server farms’ isolation environment definitions.
Answered By 0 points N/A #133891
Hi Hollis,
What you want to do with this error is ignore it and then force uninstall the program. If the program will not uninstall via the program files you can follow this link with detailed instruction on how to successfully remove the program.
You can also try Microsoft’s program removal tool that lets you force uninstall hard to remove programs due to issues and complications.
Answered By 0 points N/A #133892
Hi Hollis Riley
You can apply another technique to fix this issue. Go this Techyv post and get that technique.
Error – 29501 Citrix Presentation Server uninstallation
