Uninstalls Microsoft Office Visio 2010 Completely
Hello experts, I want to uninstall Microsoft Office Visio 2010. I am having problems in uninstalling the software, kindly guide me through the steps to permanently and successfully uninstall it.
Step1. Log on into your administrator.
Step2. Close all the running programs including the anti-virus also.
Step3. Hit on start, choose settings and then hit control panel. Select the Add/Remove Programs.
Step4. In the given list of the programs find Microsoft Visio 2000. Pick modify or choose Add/Remove.
Step5. Choose Uninstall Visio and then select next.
Step6. Hit on Start menu search for Run. Type “regedit” and select OK.
Step7. Select My Computer and then press F3.
Step8. Type vim.exe and then select Next.
Step9. Press delete if any results appear.
