A Unique TV Set that comes in 3D and Unique Feature
Hi!
I am still looking for the best television set came across with one unique set. It is called Samsung OLED KN55S9CAFXZA. I want to know how much is the price for a 40" inches set? What are the features of this TV? Why is it oblique? What is the purpose of making it oblique? Can I also use it as my computer monitor? What are the sizes available for this television set? Is there any alternative tv that I can purchase rather than this or much better than this one?
Answered By 0 points N/A #165978
The Samsung OLED KN55S9CAFXZA provides enriched and clear picture quality than any other television sets. The amount of this extreme television set will range from $2,999 up to $10,000. The smallest size offered is 55” television set. The oblique design enhances the viewing aspects in this television. You go to any angle and location in your room that will not have any angle problem.
Using this television as your computer monitor will not be advisable. Because of its massive size it will be difficult for you to move your mouse and work in to different pages and windows.
The only available size of this TV is 55 inches. Purchasing this for me is not beneficial. Off course it will be very extravagant. Having the only oblique TV. You will not see any difference with normal LED-Smart TV. The only difference with this TV is that it is oblique. The rest of the features are being offered with other older versions of the TV.
Here are the best features of this series.
1. Curved OLED TV.
2. 54.6" Diagonally.
3. 3-Dimensional Support
4. Smart TV with Apps, S-Recommendation and Full Web Browser.
5. Multi-view.
Answered By 0 points N/A #165979
1. The model you mentioned is 55 inches not 40 inches.
2. It’s available in three sizes 48, 55, 65 (inches)
3. The reason of curving:
You can have better visualization i.e. uniform and balanced view from your living room.
The depth of the picture can be filled
Generates three dimensional effects which surround the user and gives magnificent quality
The person who is in center , feels sides are far away in case of flat TV but here this problem eliminated.
4. Yes you can use your TV for monitor of computer as it's having RS-232 port and USB port.
5. Some important and good features of the TV is
Full HD, Ultra contrast, Quad core processor, smart hub, Full web browser, Built in pop-up camera, Motion control, Voice control, Smart Connectivity, 2D-3D full HD, Dolby and DTS sound system, Various connectivity i.e. WIFI, LAN.For full specifications see the attachment.
Package includes four pair of 3D glasses, Smart touch remote control, one connection box (this box is the heart of the system, and most important is its software can be upgraded time to time )
6. Selection is different with person to person and application to application
