m raju
Posted on - 07/22/2016
Often while working on UNIX report servers we come across an error message which says error REP-50125 has been encountered along with details of the exception and often without it. How can we deal with this wide spectrum report to identify the problem and solve it?
UNIX Report Server Error REP-50125
This error message can be a result of a wide array of scenarios for trouble shooting assistance. The most common issues in this series are as follows with mentions of how to solve them:
a) REP-50125: Failed to parse server < {0}> element: This one is an error in which decryption called failed on an element. We have to check the encryption attribute for the element involved and this can vary from case to case.
b) REP-50125: Failed to parse server config file {0}: This one is caused due to problems in xml syntax. This can be looked into by compiling the configuration file separately in any standard compiler that would point out errors.
c) REP-50125: Failed to initialize {0} destination. Nested Exception {1}: This occurs when destination initialization fails. To solve this we need to check the configuration destination. These three are the most common issues which network engineers often face.
