Unknown DirectX Error League Of Legends Fix
Today when I entered into the league of legends game, I’ve encountered unknown DirectX error. I’ve tried restarting my PC but couldn’t solve this problem. Is there any easy fix for this error?
First, try updating your graphics driver if it’s not yet updated.
Other than that, you can try out this solution:
• Go to this site
• Download this text file.
• Open the location of your league of legends games and go into the config folder.
• Now drag the downloaded file into that folder.
• Rename the dragged folder and replace it with the older one.
I hope this helps you out.
The problem there is with the video card. First option is to try updating the video card driver. This may fix the problem with Microsoft DirectX. Try downloading your video card driver from the following manufacturers if you are using one of these:
You should also check the system requirements of the game you are playing. “League of Legends” supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 3 GHz or faster processor with SSE2 support, 1 GB RAM, 12 GB free space, and Microsoft DirectX 9.0c-compatible video card with Shader 2.0 support.
On the other hand, if you have a compatible system but you experience problems, try downloading the “MinConfig” settings file. What this file does is take your game settings down to the bare minimum configuration which is helpful when your current game settings are too high for your machine to load into the game. First, download MinConfig.zip then unpack the ZIP file.
Next, log in to your League of Legends account. After this, open Windows Explorer then navigate to the folder where you extracted the files then copy the following files to “C:\Riot Games\League of Legends\Config”:
If you are prompted, click to overwrite files. Lastly, start a Custom Game by yourself. This should give you the minimum configuration settings.
Notifications
