Hello experts,
It seems like Angry Birds can’t run on my new tablet. I have the same version installed on my phone and is working great. I don’t know why the same version of game is not working on my new tablet. Please someone help me to fix this one. Why I can’t run the game on my tablet?
Thanks experts!
Unknown Error
An unknown error has occurred
Please tell Riot Games about this problem.
We have created a report about this error for you to send us.
Send Error Report   Don’t Send
Unknown Error Angry Birds can’t run on my new tablet.
When installing game applications on mobile devices, it is very much the same as with installing programs on the computer where you need to know the requirements. When installing a game on a personal computer, you only need to know the supported operating systems. But when installing a game app on a mobile device such as a mobile phone or a tablet, you have to consider several things aside from the handset’s operating system.
Most of the popular mobile games now run on Android and Angry Birds is one of them. With Angry Birds, you should check if that version you downloaded supports your phone’s current Android version. If not and it requires a much higher version then you should update your phone’s software. Also, not all Android devices can be upgraded up to the latest Android version.
Older Android devices can only be upgraded up to a certain level which means you cannot install any apps or games that will require the latest Android operating system. So, in your case since Angry Birds is available in many different versions, check your version for its supported handset operating systems as well as your tablet’s current operating system and up to what version it can be upgraded.
If your game requires the latest Android, then check if you can upgrade your tablet to the latest Android version. But if not, maybe just shift to a different version that will work on your tablet.
No need to worry it seems like you have used same apk of the angry bird game for your phone and tablet. There is a big difference in the applications which run on tablet and phone, as the screen size is different, resolution is different.
May be you try to install the angry bird from the Google Play store from your tablet, it will show you the application for your tablet, from there you can download the latest angry bird for your tablet.
Hi, you are able to play the game on mobile and the same game angry birds riot is unable to play on tab shows that your is not compatible I mean does not suit the game requirements. If you have checked for the requirements and also if you would have mentioned which tab and what android version you have may solve the problem easily.
