Unknown error related to bluetooth-need solution
I have got a Bluetooth related error message which I have enclosed below.
I am looking for a solution or cause for this problem.
I have not learned anything about this problem through my searches.
I am looking for someone to identify this problem and kindly notify me.
Please, should someone find the reason behind this error help me getting enlightened.
Benjamin Morgan
Error:
Compatibility issue between a Bluetooth service and Windows
A service associated with a Bluetooth enabled device isn’t compatible with this version of Windows. This service might not be required for this device to work properly.
If your Bluetooth enabled device is working properly, you can ignore this error. Other Bluetooth connections and your devices will continue to work properly.
If your device is not working properly, or if you believe this service is necessary, contact your device manufacturer.
