Unknown problem occurred in my Computer
My monitor suddenly went black although the power is still on.
The display did not show up and no error messages were shown.
How to fix this problem..?
To resolve a black screen issue:
If the issue persists, please go to https://support.microsoft.com/en-us/products/windowsfor further assistance.Â
If you encountered this problem while Windows is running, check if the LED power indicator of the monitor is still activated. If the LED is still turned on, disconnect the monitor cable from the video port at the back of the CPU. After this your monitor should display something about a disconnected cable and then will disappear again after a couple of seconds.
If this happens, there’s no problem with the monitor and it is the video card that needs to be checked. But if nothing showed up on the monitor after disconnecting the cable, press the power button of the monitor to turn it off and then press it again to turn it back on.
You should see an image on the screen. If not or there’s no image, the monitor needs to be checked or replace it. If there’s no problem with the monitor, the problem is probably in the video card. Press the power button of the CPU once to shut it down and then open the CPU case.
Transfer the video card to another slot and then start the computer. If nothing appeared on the monitor, try a different video card if you have a spare or purchase a new one.
