hakam
Posted on - 08/24/2011
Hello!
I have a problem to discuss with you guys , i hope i would be provided with the solution. From two or more days ,
My computer is not working well , there is something wrong. Whenever try to install any application , following windows
appeared and software installation doesn't proceed. It is a run time error
Error
A Runtime Error has occurred.
Do you wish to Debug?
Line: 37
Error: Unknown runtime error
Unknown Run time error occurred
The error usually occurred when you are web surfing because it is informing you that there are some viruses or bugs in your system or program. Trojan is attacking you're computer and affected your registry though you have your anti- virus, it cannot restore the damages in your registry. Some improper removing of registry, improper shut down of you computer and files downloading and installing are also the cause of this kind of error.
You can simply resolve this problem by restoring your corrupted registry items. Then try to uninstall any application that you recently installed in your system. Check if which of them are causing the runtime error. Don’t forget to always update your anti-virus, so that your system is protected.And lastly, try to close or shut off other programs or application in your system.
