I have a new computer and am also new in computers. My computer has been working perfectly well until recently when I was surfing the internet and software from one of the sites I was browsing in installed itself without my consent in my computer. Ever since this happened my computers settings keep changing and its speed has also reduced significantly. Which software could this be and what can I do to bring back my computer back to its normal status?
Unknown Software Installed and Now Slows my PC
First of all you want to check whether there any antivirus software’s installed or not. If not you want to install one, free or better go for licensed paid version which is available on market. If you purchased or download a antivirus, just wait before installing. As you told that the system speed has been reduced significantly, first restore your system to a known best configuration by using “System Restore”.
1. Type system restore in start.
2. You will get a system restore window click next.
3. If the given is acceptable click next.
4. Otherwise select for more restore points.
5. You will find more option, click next.
6. Click finish.
