Angela King
10 points
Posted on - 10/14/2012
Hello experts,
Unlock this new mobile phone error. How can I be able to unlock Nokia lumia mobile phone? It was locked I don’t know what is the way to open it, there is a default password that needs to be key in.
Thank you.
It has been seen that most of users of Nokia Lumia complain about the locking of their phone sets. A Nokia Lumia can be locked due to any reason so it is necessary to unlock it.
1. Go to the link will be mentioned at the end and enter your mobile specifications as these are asked.
2. You will receive an unlock PIN code, simply enter that PIN code into your phone and it be unlocked permanently.
3. Follow this link http://www.cellunlocker.net/ for unlocking process.
You can unlock a Nokia Lumia 710, 800, 900 from Rogers, Tmobile, Telus or other GSM Networks by simply requesting for the unlock code from cellunlocker.net.
This service isn't free but you will permanently unlock the phone from your network and you can use different simcards on the phone later.
On the website simply enter your IMEI number which you will be displayed by pressing *#06# and enter your email address. This is where you will receive your unlock code.
Once you get your unlock code, make sure you have an simcard from a different carrier.
When switched on, it will ask you for the code and simply input.
If this doesn't work, switch on the phone without a simcard in and type this on the homescreen:#PW+CODE+7# or #PW+CODE+1#. The phone will show "SIM Restriction Off"
By the way, you can get the letter P after quickly pressing the star (*) button 3X
W after quickly pressing the star (*) button 4X
+ after pressing the star (*) button 2X.
