I am using an Xperia Z2 tablet with WiFi and from the last couple of days it started making some sound and showing double Vibrio sign even it is not used. Also, its alarm clock got turned off, WiFi not able to turn on. It looks like some problem with the tablet itself.
How can I make it work? Please advise me on how to resolve this issue. Thanks so much guys!
Hi Paul, for your Xperia problems, try this for the sound problems go to your Settings then select sound and then click or tap sound effects. Try to turn off the individual settings by so doing,m try to tweak also your sound enhancements and see any effect. Now for the WiFi signal first turn off both your Xperia and the router. Now go to your Settings and WiFi and then long press on your connection and tap Forget network, and re-set it up again. Try also to change the channel or mode of the router.
If that’s what’s happening with your tablet, try factory reset. Here’s how to factory reset Android 4.4.4 KitKat. On your tablet, go to “Settings” then scroll down to “PERSONAL” section then tap “Backup & reset”. In “Backup & reset” screen, under “PERSONAL DATA” section, tap “Factory data reset” then “Reset phone”. And that’s it.
Before factory resetting your device, make sure to back up your entire device’s contents and remove the SIM card before starting the reset. See if this works. Here are the specifications of your tablet. The Sony Xperia Z2 LTE is a 4G tablet operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies.
Sony Xperia Z2 LTE
It was unveiled to the public on February 2014 and released on March 2014 measuring 266 x 172 x 6.4 millimeters and weighing 439 grams. It uses micro-SIM card and is IP58 certified (dust proof and water resistant over 1.5 meters for 30 minutes). It has TFT capacitive touchscreen display with 16M colors at 1200 x 1920 pixels screen resolution.
It supports multi-touch up to ten fingers (10 fingers) protected with shatter proof glass featuring Triluminos display and X-Reality Engine. It runs on Android 4.4.2 KitKat upgradable to Android 5.1.1 Lollipop powered by Qualcomm MSM8974AB Snapdragon 801 (28 nm) chipset, 2.3 GHz Quad-Core Krait 400 processor, and Adreno 330 GPU. It supports microSD expandable up to 64 GB. It runs on 3 GB RAM with 16 GB internal storage.
The primary camera supports 8.1 megapixels featuring AF, HDR, and panorama and supports 1080p video recording at 30 fps and 720p at 30 fps with HDR and stereo sound rec. The secondary camera supports 2.2 megapixels and 1080p video recording at 30 fps.
It has 3.5-millimeter jack featuring 3D surround sound and active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP and aptX support; GPS with A-GPS and GLONASS support; NFC; infrared; FM radio with RDS support; and microUSB 2.0 with MHL 3 TV-out and magnetic connector. It has built-in accelerometer, gyro, and compass sensors.
The pre-installed web browser supports HTML5. It runs on non-removable Li-Po 6000 mAh battery with standby time up to 1,240 hours on 2G and 1,200 hours on 3G. Talk time is up to 13 hours via multimedia. It is available in black and white colors for the SGP521 model and black color for the SGP541 and SGP551 models.
1....
