Unreal tournament three installation error 1935
I am a fan of ut3 but in my new pc i am not being able to install unreal tournament three……
Almost every time it ends up showing the error 1935 code.
Error 1935.An error occurred during the installation of assembly component {98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}. HRESULT: 0x80070424."
Best Answer by Davidson Mudge
Answered By 0 points N/A #163100
Hello there Sevenseven, my suggestion to your problem is first remove all the premature installation files. and then download the .net framework 4.5, cause sometimes having an outdated .net framework
heres the link that i provided for you. you can download i in Microsofts download center. link
hope this help you solve your problem have a nice day
Answered By 0 points N/A #163101
Hi seven,
     This error is caused by a program that is running on the problem had encountered a problem that interrupted the installation. Error 1935 is often caused that the .Net framework on the computer is having some issues. Best way to determine it is by running a repair on the .Net framework 4.0 if not present look for .Net 3.5 and then proceed with the repair same as how you do it with other software. Beforehand, make sure that both .Net is enabled under Windows features on control panel.
