I faced a problem while I was doing work on my project. The problem came at the time of shutting a door in the middle of the two rooms. Later with the collapse I have attempted to explore my project one more time however EVO shows an error message. What should I perform at this time?
Need assistance.
Error message: “Unrecoverable error during geometry update”!
How to solve this?
Thank you for choosing Techyv.com to provide you with expert solutions to your IT related problems.
Your problem was created by embedded walls resulting in a few issues with some bad geometry.
To fix this issue, open up the file in R2012.
Select the following elements by ID number and delete them: 156453; 1485317; 1564381; 788679; 1564378.
I hope this helps solve the problem.
I would recommend as a further solution you download and install the 'Update' Repair Tool. This is a tool that has been designed to diagnose and repair various Windows issues.
Hi James,
As Fernando mentioned above this could be caused by some offender objects so removing them and running again is could be a solution but if that does not solve the problem you need to do a little more. This is often noticed that this similar kind of errors are coming due to memory issues , so do a memory test as well.
Hope this will help you in solving your issues. Thank You.
