Unrecoverable error in running a script with QTP 10.0
I need help with running a script in QTP. I have encountered an unrecoverable error while running a script with QTP 10.0.
It prompts the following error message “ The test run cannot continue due to an unrecoverable error.
Failed to run script.
Description: The specified module could not be found. Line (1)” “RunAction”Action 1”,oneiteration”.
Any help will do.
Thank you
Answered By 0 points N/A #153495
What do you mean by unrecoverable?
Is it that the script does not work any further or the application terminates It must be that the script does not work.
If not then it is the application problem.
Else the script has the error. Then I would like to know what the script is?
The script must contain certain functions or works that are not desirable by the environment at which it is run. Unlikely the script must undergo certain changes as applicable to it.
In other words the main problem to it is that the application needs to be rebooted for any errors in the application itself.
