Do you have the same experience on your HP touch screen? I have an HP 2310t Multi-touch LCD Monitor. After several weeks of use it suddenly becomes unresponsive. Try to power on off but still cannot receive inputs signals. Please help this should be an input device also not just a display Screen.
Unresponsive touch screen LCD monitor
It seems that you have changed settings on screen. Try to fix it from control panel and if possible to reset it. If it still has problems, try HP support and tell them your problem as soon as possible. It may be probable that your HP touch screen has a hardware problem.
Hi there, if there is problem with the HP touch screen then you must contact the PC repair person or technician as it the case of touch screen so we people cant go deep in to repair it. Please consider to contact a PC repair technician.
