Hello all,
I am using F-Secure to protect my system and today i started receiving this error message. Can anyone of you help me understand what this error is and how i can fix this.
F-Secure Installer
Unspecified error. Please try again.
(Error code: -25)
OK
Thanks
Unspecified error occurred in F-Secure Setup 2011
Hello Rabbeca,
This error usually happens when your system cannot allocate the specific file you are trying to access. There may be a missing file that is vital in the operations of the software F-Secure. The best thing to do is look for the patch file of what you are missing. You can also re-install your F-secure and make sure that no file has been lost or corrupted. You should only install an original software so that it will never have the same error again.
Hope this helps you.
Gresham Yvonne
