Hello folks,
I'm new to apple products. It's mail apps looks great, works well also. One of my friend told me earlier to use unsubscribe plugin to get rid of unnecessary emails by unsubscribing with one click.
But, after clicking unsubscribe button several times and on several emails, still I'm receiving those emails regularly.
It seems apple mail's unsubscribe plugin haven't worked at all. Am I doing it wrong or this unsubscribe plugin stopped working?
Unsubscribe Plugin won’t work with Apple mail.
Hello Dear,
Apple has a great email application but when you are unsubscribing from any advertisements or unwanted emails you also have to write your email address to unsubscribe to that specific email type.
By using Apple's unsubscribe plug-in you also have to write your email address on there in order to completely get rid of unwanted emails.
Hi Brien,
First of all check out for latest update for your apple mail application and also check out for new version of that plugin.
After updating software try to unsubscribe by just one click as you want to do.
If it seems not working then easiest method is to uninstall that plugin and try to install latest one.
Thanks
Hello!
I have confirmed about the matter. I am giving some significant solutions regarding this complex trouble.
You should check your main folder where it is installed. It is seemed that it is stored in library folder of Bundles of Mail of Macintosh HD.
Then you can delete the unwanted applications. You can subscribe the mail application via your credit card. You have to make sure about the matter of requirements of system configurations. If the system doesn’t meet the requirement then you may have to uninstall the application.
Regards
Shifflett Laurel
