Hello, I bought VIN tv-hvr-950 yesterday. But when I am trying to record a program, I am getting an unspecified error showing. I contacted the customer centre who couldn’t solve my problem. Do you know anything about the solution of this error? If so, then please tell me.
Unsuccessful program recording with VIN tv-hvr-950; Error 0x80004005 occurs
Hello. As your VIN tv-hvr-950 is showing an unspecified error, the best thing that is recommended to do is to clean your system registry so that all error files are gone. For this, use a reliable registry cleaning software or application. There are many of them- you can try Wise Registry Cleaner which is very well-reputed registry cleaner, you may try CCleaner, Eusing Free Registry Cleaner or WinASO. This is highly likely that your problem will be solved. But in case if it does not work. Do not worry. Take it to the retailer and ask for another product for change and if possible, report the issue to the product manufacturer company. Hope your problem gets solved.
