Unusual closure of Starry Night application
Please users help me to find out the following error: "Starry Night…needs to close" error message. is my graphics card incompatible here. I'm using a 8500gt oem.
Starry Night Application
Starry Night Application has encountered a problem and needs to close. We are sorry for the inconvenience.
II you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem
We have created an error report that you can send to us. We will treat this report as confidential and anonymous.
To see what data this error report contains, click here,
Send Error Report Don’t Send
Answered By 590495 points N/A #91178
It is possible that your current operating system is not compatible with the application. If you are using Windows Vista on your computer, then maybe this is the reason why the application suddenly exits with an error.
Starry Night does not fully support Windows Vista and its compatibility with this operating system still depends on the version of the installer you have. I’m not sure if the installer for this application comes as a download version or in a disc.
If you have your installer with you, check in your installer if Windows Vista is listed in its supported operating systems. If it doesn’t, check the installer carefully on what operating systems it support.
I think Starry Night fully supports Windows XP and Windows 7 both the 32-bit and 64-bit versions.
You need to check your installer for the operating system it supports. If you have the installer disc, the supported operating systems are printed on the disc.
If your operating system is not included on the list, you need to replace your operating system with any of the listed platforms.
