Unusual Windows error message on Win XP machine
I was not sure if the below error message was a kind of fun …..
Hey…don’t make fun of Windows” with red X
I have Win XP on my machine; I get this unusual error message sounds like a prank though; it keeps popping every now and then.
On top of error box it says “Hey… don’t make fun of Windows” with a red X in the box and following message appears with ok and cancel options.
“Windows will crash on you… better be careful!
Monitor will burst
Keyboard will be sliced
Mouse will be murdered and you will be through out of windows!”
I was not sure if I need to reinstall something.
Could it be a Trojan/Virus or a spyware?
Best Answer by jhony_deep
Answered By 0 points N/A #85277
Dear Deborahbaker,
This message clearly shows that you have a serious virus in your system and your antivirus has been infiltrated and trapped by viruses and not in a position to repair or delete these viruses.
Suggestions:
Uninstall your antivirus.
Try to scan your system online through https://www.bitdefender.com/toolbox/ and remove viruses which you found.
Secondly, download a fresh copy of the best antivirus from the web. After installation and updating of virus definitions, you should run a complete thorough system scan to get rid of this error message. During or after scan, which viruses you found, just delete that files. There is no need to quarantine.
Jhony
Answered By 5 points N/A #85278
These types of errors will degrade your system performance better to format the system.
Thanks,
Anilkumar.
