Update for Apex Launcher couldn’t be downloaded due to an error 921
Hello experts,
I was trying to update the Apex Launcher App from the Google Play Store but an error message appeared during the downloading this app. I restarted the Play Store to download this app but the same error message displayed. How can I solve this problem? Is this a problem with my Google account? I really need your suggestion to resolve this matter.
Error
Update for “Apex Launcher” could not be downloaded due to an error. (921)
Answered By 5 points N/A #177674
Hi Thomas,
Regarding to your problem here are some ways to solve your problem:
  • Delete the cookies for your device to avoid having this kind of error or other error that can possibly encounter. To do this just follow these instructions.
                Step 1: Go to your device Menu > Settings > Application
                Step 2: Select the Manage Application the click All.
                Step 3: Choose the Google Play Apps Store
                Step 4: Then clear all data and cache
  • You can also try to use another account to update the application if you don't encounter the same error it means that your account has a problem so you have to make a new account to be able to download and update your apps.
  • Try to use another device then install the application to that device to know if your device only encounters that problem.
I hope this can help you.
