Update the Dell USB Optical mouse driver
I want to use a Dell USB mouse with my laptop, and for that my device needs to update the drivers. Please tell me how to update the Dell USB Optical mouse Driver?
Dell releases new Drivers frequently to take care of compatibility issues with the latest peripheral devices. To connect the USB Optical mouse to your Dell computer, follow these steps:
• Search for Device Manager in the Start menu.
• Select ‘Mouse and Other Pointing Devices’, and then click on the mouse you would like to update.
• Click on Driver, and then ‘Update Driver’. Check the box of automatic search for the software.
• Follow the instructions of the software, and then Re-start your computer.
Note: Before updating the Driver, make sure that the USB Mouse is connected to your laptop.
