Update drivers and Windows in Computer
First is you have to determine the hardware before searching for the specific drivers or software in a device and try to make sure that you know the manufacturers model of the device that you are using. If you’re looking for software or drivers of the device inside your computer and it in manufactured by an OEM you can find the drivers in the manufacturer’s web page, if the manufacturer is still in business the driver’s is listed on their webpage.
But if it’s out on the business the maker of your hardware device do not offer drivers of your product, you can use a third-party company that specializes in making out of date and obsolete drivers.
Hi Prakashkumar,
Firstly you must be aware of the system specifications which need driver necessarily, Like VGA, Audio, Ethernet and at times Motherboard. For this go to Start Menu, click Run and type “msinfo32” in main view you may system summary and there you can see all information about cards attached to the system along with model number. Search for drivers with exact name from internet and install.
Now if you want to see already installed drivers, move down and expand Software Environment, click “system drivers” the installed software drivers will be showing whole path and others are not available. Check and verify.
Hi Bose,
It will be the best solution if you select the system to Windows automatically download recommended drivers and detailed information. it will update all you hardware and devices. Thanks.
Notifications
