Hello, I am having a problem in using MacAfee. When I was trying to start the updater I got a problem with an error code 718. I reinstalled the whole system but no result found. Do you have any kind of idea that can take me out of this problem?
Update error pops up with Macafee
Dear
McAfee customers are facing this type of problem. You need not to worry about this.
You need to run the McAfee Virtual Technician; this software will scan your system and repair your McAfee Installation.
To launch McAfee Virtual Technician you need follow the following steps. Â
Step 1: Go to the links below and download the file. (If you receive a file download security warning click Ok)
Download link: http://us.mcafee.com/root/mvtapp.exe?eolexm=vste
Step 2: After downloading the program click on the program to Launch McAfee Virtual Technician.
The program will scan your system and automatically fix your problems which is aborted you to update your antivirus.
