Hi Guys,
I tried to update Excel 2007 from Excel 2003 Add-In. I failed to do so. It appeared some codes. I did not understand that codes. How did it happen?
Have you any idea? How can I get a remedy of this issue? Please help.
Thanks for the solutions.
Update Excel 2007 from Excel 2003 Add-In
Hello Jeffrey,
You are prompted with that error simply because you cannot update newer version using the add-ons from the older version. Every software versions, the features are upgraded and sometimes the error occurred if you are not going to save your file that would be compatible with the older version. So, just find a version of that add-on which is compatible with Excel 2007.
Hope it helps.
This add-in adds a Get Started tab to the Microsoft Office Excel 2007 Ribbon. Commands on this tab give you easy access to free content on Office Online that helps you learn Excel 2007 quickly. In the link given below you can download excel 2007 plug-in. Please check your system requirements first. There you can find install instruction too. Here is the link :http://www.microsoft.com/en-us/download/details.aspx?id=11857
