Update Problem – Looking for solution
Hello friends, I am using 1 password for quite some time now but now I want to update it, and my system won't allow me to do it.
I always get the following error message on my screen:
Setup
Setup has detected that Internet Explorer (or Windows Explorer) is currently running. Please close all instance of – Internet Explorer – Windows Explorer Then click OK to continue, or Cancel to exit.
Alternatively, you might want to restart your computer, and try again. OK Abbrechen I don’t know what it means when I don’t even have the internet explorer installed on my system. However I am using Windows explorer on my system. What should I do to get rid of the error?
Your suggestions are awaited. Regards,
John
Answered By 0 points N/A #140516
Hi friend,
you did not clarify that which password you want to update is it your computer password or another, ok need not to worry then i am here to solve your problem  I think it is not a major problem sometimes when you want to update your password some confirmation and programs need to stop or need to restart you pc just it. If you didn't restart your pc then do it and i think your problem will be solved.
One more think if you want to change any account password which can be your bank account or any type of account password then first you confirm that the password is saved then explorer can want to confirm it and for that reason many times some unexpected problem can be shown to you. If you need to restart your pc then just restart it and you will get fixed your problem.
Thanks
Answered By 590495 points N/A #323107
I often receive this kind of message whenever I install a program before on Windows XP. Setup just wants that no window is open when installing the program. You can actually ignore this message and continue with the installation by clicking “OK”. If this doesn’t work, restart the computer then install the program again.
On the other hand, if you are getting prompted to enter the administrator password every time you change a setting on the computer, it means you are not using an administrator account or you are not the administrator of the computer. One workaround is to disable the administrator password using the built-in “Administrator” account.
If the current user account you are using is not an admin account, you can use the built-in administrator account in Microsoft Windows to change or delete the password of the other user account. The built-in admin account in Microsoft Windows is automatically hidden once you create a new admin account. Since the built-in admin account is already hidden, you need to unhide it.
Press the Windows key + R to bring up the “Run” dialog then type without quotes “cmd” then hit Enter. In the command prompt window, type the following then hit Enter:
  • net user administrator /active:yes
After this, close the command prompt and restart the computer. Now, log in using the “Administrator” account in the login screen. Once you are logged in, repeat the same steps to start the command prompt. In the command prompt window, type the following then hit Enter:
  • net user [username] [new password]
Replace “[username]” with the username you want to change the password. Replace “[new password]” with the new password you want to use or don’t specify a password to delete the existing password of the account. If the target username contains a space, you need to enclose the username in quotes like this:
  • net user “[user name]” [new password]
