Update records into streams videos using Google chrome
I'm searching a way to update my records into a stream video using a software that can be found in Google Chrome.
What software is the best one to do this operation?
Dear fogel,
You did not mention what kind of data you want to update in the video and what kind of operating system you are using. However it seems that you can do this by stream video editor. You can use any kind of video editor compatible with your operating system. In my experience total recorder is the best software for this. You can download this from this link- http://www.totalrecorder.com/downloads.htm
This will cost you money. If you want free software then search with Google.
Thank you.
