Update version of Kindle Touch Software
An update version of Kindle Touch Software has been released, from where I can download this for free?
Dear Rachel,
It is very easy to download the latest updated version of the kindle touch software version for free. The latest version is Version 6.3. You can either update your already existing version or download it for your device. It is free software. To download it automatically, you can do it manually and extremely fast. You must have the USB cable. If you want to download the updated version or to update the software for free. Just go to this website; https://www.amazon.com/gp/help/customer/display.html?nodeId=200790620
You will be able to download it for free and very fast. I hope this will be of great help to you. Thanks and much regards!
Yes, there is already an update available for Kindle Touch software from Amazon | Kindle Touch Software Updates. The update includes new features together with an updated user interface. There is no need to manually download the update because the software is automatically downloaded and installed but that is for Kindle Touch customers only. But there is no problem if you want to download the software manually and update your device using the USB cable.
And another important thing about the update, your contents need to be indexed again to support the new features. So it is recommended to connect your device to a power source while doing the re-indexing because the process will require more battery. The new features included in the software update comprises the following: Whispersync for Voice, Time-to-Read, new user interface, recommended content, improved parental controls, can navigate through comics and graphic novels, book covers, and improved book samples.
Hello mates, these were brilliant opinions and I wish to say congratulation. I usually appreciate your concept and attaching links for appropriating according to my wants. The site that you have provided are very useful wherein the viewers like me could easily download the Kindle touch software. By getting knowledge from your content, I have learned that Kindle Touch customers can update automatically download and install, as well manually download the software update and install via USB. Also I have got an unknown idea, for supporting new visages in this update, my Kindle Touch require to re-index my content, during that also require power source as well your other root of learning were also needed to keep in mind. Very vital variation so thanks mates for endowing your crucial guidelines. Take my regards.
