anonymous
7060 points
Posted on - 08/09/2011
Hi!
I am a Virex internet security Antivirus user. To properly defend my computer I need an update of antivirus.
But I do not know how update this Antivirus.
Now I require the update process of this antivirus.
This is most essential for my computer's protection.
Update Virex Antivirus for my PC Protection
As a matter of fact the Virex Antivirus Software consists of 2 elements: the main software DAT files and the virus definition files.
The main program usually does not need to update by itself, except when a recent version becomes available. The DAT files are those files that have the concrete virus definitions, thus should be regularly updated. So if you follow the following steps you can update the virus definitions of Virex x.
The simplest method to do this is to run your Virex software and click on the ‘e-update’ button. Virex will then voluntarily download latest virus definitions file (DAT files). In case there is a new update, install it so in this way your Virex antivirus software will be updated at all times. You can also schedule the e-update by following these steps:
Create a schedule to do the e-update automatically at certain times (for instance startup, daily etc). In this way you can access this schedule from the Schedule menu in the Virex program.
Hope it will keep your system safe from virus, and your computer will be well protected.
Hello Amatin2634,
It is an easy process for you to update the antivirus. You just need to locate the virex identity icon in the task bar of your computer and then right click on it, and then choose update. The antivirus will go online to look for the latest updates and then automatically update itself. For this process you will need to have connected your computer to the internet.
You can also choose to download the antivirus update and then update the antivirus manually on your computer. Just Google for virex antivirus update and then download it, save it in a folder on your computer and then open the antivirus and then in the tool bar look for the option to download the antivirus from a directory.
Regards
Clair Charles
By default, all security programs like antivirus and internet security update by itself. You don’t need to update the program manually. It is part of its programming to check for an update regularly then download the update and install it to update program modules or components and particularly the virus signature database. The only thing you need to do is to make sure your internet connection is working.
Most antivirus and internet security programs are configured to check for an update on a regular basis, normally, once a day. But there are security programs like ESET that checks and installs updates multiple times a day. If the antivirus failed to check for an update that day, it will check again the following day. Just make sure internet connection is always up and running.
Of course, you can also do the checking manually. To do this, start your antivirus then navigate to the “Update” menu or tab and click “Update”. This checks for an update and install it if an update is available. To learn more about Virex or to download the new version, go to Virex Antivirus.
