Updated TortoiseSVN Error encountered While Working.
I’ve been having several problems after I updated my TortoiseSVN. Can someone help me out?
Every time I bring up the SVN menu by right clicking on a folder, I see two of them: previous version and the updated one.
Another problem is, every time I do an action in TortoiseSVN, a “No path or path file specified on the command line!” error appears, as seen below.
How do I fix this?
I need help.
Thanks!
Answered By 590495 points N/A #82224
If this usually happens every time you right-click a folder, try restarting your computer then try it again.
If it’s still the same, try doing a clean installation of TortoiseSVN just to restore it to its default configuration and fix any corrupted files that may have developed in the system in the long run or maybe after you updated it.
Uninstall TortoiseSVN then check your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks or Norton Utilities. Restart your computer after the disk check. After booting, install TortoiseSVN again then check if this fixes the problem.
You may also try checking your system for any sign of infection. Update your antivirus then run a full system scan on your whole computer. There are instances where a virus causes this type of behavior like with your application.
If you are using an older version of the program, you may try upgrading it to the latest version, TortoiseSVN 1.7.7. This version is available in 32-bit and 64-bit versions. To download TortoiseSVN 1.7.7, you may visit TortoiseSVN — Downloads — TortoiseSVN 1.7.7.
