dave tuttle
60 points
Posted on - 08/22/2012
I make sure I download with an active BitDefender. I find it very reliable, and it works great on my PC.
I was surprised when I encountered this error “UpdateNoPackFile download [msssrs.flt] file different on the list.
What does that even mean?
You said that you have downloaded with an active BitDefender and you found it very reliable on your PC, It worked great on your pc and so on.
             Let me tell you that the Bit Defender antivirus is an award wining brand therefore there is no doubt in its working power. The error you are talking about shows that there is some problem in downloading the update file. The file it had downloaded is not reliable. Now you have to follow the following instructions.
·     Try downloading the update file again.
·     Contact with the crating company of BitDefender and tell them about the problem. They must have an update file for your copy.
·     But first of All make sure that BitDefender that is being used by you is a registered copy.
it may helps you.
Regards
Rikkiyosa
