Hi there!
I have just updated Acrobat Pro X from Acrobat Pro 7. When I create a PDF file I try this "epilogue.ps". in that "epilogue.ps" I added a link “(c:\temp\bookmarks.bmk) run”. But its not working. It shows an error message like
Processing epilogue.ps…
%%[ Error: undefinedfilename; OffendingCommand: run ]%%
Stack:
%%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
%%[ Warning: PostScript error. No PDF file produced. ] %%
But it worked well in Acrobat Pro 7. Then what’s wrong with Acrobat Pro X?
Updating Acrobat Pro X from Acrobat Pro 7
Hey Arnold!
You are facing the same problem that one of my friend was facing too. We did everything to solve this problem but we were unluckily failed to succeed. We were stuck badly in this problem and we have to do work with Adobe Acrobat pre.
Anyways we decided to contact the Adobe Acrobat support; we thought that they might be able to solve our problem
We describe the whole situation to them. Luckily the solution they told us had fixed our problem and we were very thankful to them
Now here what you need to do is:
1. First of all invoke the Distiller withe F flag.
2. For example "C:Program FilesAcrobat x.0acrodist.exe"-F
3. Now your problem is solved.
Have fun
Thanks
