I am using Cisco ASA 5500 Series firewall and I would like to update my Cisco Adaptive Security Appliance software with the latest version 8.4. But I want to know if this will make any changes in the NAT configuration? Please help.
Updating Cisco Adaptive Security Appliance Software
•Cisco ASA 5500 7.0 and also later on
•Cisco ASDM 5.0 and later on
The actual info with this document was created in the disposition in the particular laboratory atmosphere. Every one of the inclination utilized in this particular report began with a shaped (default) design. In case your system will be live, ensure that you understand the potential impact associated with any command.
Related Items
This kind of design also can be used along together using Lake herring Pyx500 Ordering Security Equipment Computer application Interpretation 7.0 as well as later.
Select Tools > Improve Application. in the Residence frame of the ASDM.
Select the form of image to upload from your computer menu.
Click View Neighborhood Files… or kind the road within side the Local FileCourse field to stipulate the place of the software image on your Personal computer
Click Browse Flash….
Type A Search Flash Duologue window seems with the computer filename came into automatically. If the filename will not seem, come in this manually inside Computer filename field. Click Alright when you're carried out.
Hello Jude,
In migrating to version 8.4, note that the NAT feature has been redesigned for increased flexibility and functionality. When using NAT in the previous version, you had to specify the mapped addresses and ports in an access list for all features that uses access lists. In the latest version, for several supported features, you must use the real untranslated IP address and ports.
In the migration, The NAT configuration will not be affected but will be migrated as well. When the NAT configuration is migrated, the following file is added to the root directory: nat_ident_migrate. The presence of this empty file shows that the NAT configuration was migrated successfully and prevents remigration at boot-up.
Thank you.
