Updating Folder Design Manually Problem
Posted on - 06/04/2013
I have experienced a problem with Notes Client 6.5 that runs with Windows XP when I try to run "Update Folder Design" manually. If I do it automatically I have no problems, but manually it doesn’t matter which folder I pick, because after I start the upgrade this message appears: "Field is too large (32K) or View's column & selection formulas are too large". Do you think that 700 nested folders are too many for the Notes Client to handle?
