Hi! I have been using Google nexus 5.0.1 before and it was a great experience. Everything worked fine. Now I am manually updating it to 5.1 but I don't know if its without a risk? I mean is there any chance that I might lose all my data during this update because I cannot afford to lose my data at any cost. Please reply asap. Thanks!
Updating on my Google Nexus 5.0.1
The Android 5.1 having some problems and got the negative feedback from the users recently. The Nexus users are complaining about problems like random restart, connectivity issues, slow performance etc. So I would suggest you to don’t do the upgrade right now. You can upgrade it after sometimes so all the issues regarding Android 5.1 to be resolved. Its better to use Android 5.0.1 on your mobile right now.
