Mickhel
70 points
Posted on - 10/10/2011
Windows XP is really good. I have used it. Now i need to update it. I do not Update it. I am trying many more times to update but I failed. There are many An option I fine Microsoft windows site but it is so hard for updating. It show so Easy to update but so hard to doing that. How could I do that finally?
Luiz
Choumen
5 points
Updating problem Windows XP – may be
Really, Windows XP is good. I used it before but now I am using Windows 7 Professional (genuine copy) as now I am a member of MSDN family. Though I did not update Windows XP before, but I researched more time on the Internet how to update Windows XP and I have found different options for doing this. From these researched ways, I found a YouTube video which will give you the full instructions to update your Windows XP.
I hope this will be very useful for you to update your Windows XP drivers.
Good Luck!
Choumen
ken12
Dear Mickhel
There are various ways of updating windows XP,
Go to start menu, and click on the control panel. In control panel click on system.
A dialog box will appear, Click on automatic updates tab.
Select Automatic Updates, the computer will automatically, download and install windows XP updates on your computer for as long as you have a good internet connection.
You can also go to the start menu and click on windows Update, windows updater will automatically scan your computer and provide you with necessary updates for your computer. Click to install them.
Also you can visit the Microsoft.com homepage to search for available updates for your windows XP.
Good luck
Choumen
