rajasingh
Posted on - 04/05/2012
I have an installed Nokia Qt SDK in my PC. It did an automated updated but this error (see below) popped up. I don’t know what to do next, though. Can someone help ASAP?Â
I can’t use the said software and I need it ASAP.
Installer Error
Error during installation process
 (com.nokia.ndk.experimental.harmattan.nokiameegoapi):
The output of
C:QtSDKMaddetargetsharmattan-nokia-meego-apibinqmake.exe-query is not parse able. Please file a bug report with this dialog.
Retry Ignore Cancel
Updating of Qt SDK components failed
Try cancelling the installation and then restart the computer. After rebooting the computer, try installing it again. If you still encounter the same error, abort the installation again then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, PC Tools Performance Toolkit, or Norton SystemWorks. Try installing it again after the disk check.
If there seems to be no way to install the application, I think you need to check its system requirements. It’s possible that this version is not compatible with your operating system. Try installing the version that fully supports your operating system.
