Updating Tumblr Blog in Ubuntu
I wanted to update my Tumblr blog in Ubuntu without having to launch a web browser, is there a seamless integrated way to do it?
Hi Doriswneil,
Yes you can handle your Tumblr blog from your Ubuntu without the use of a web browser. That would be using Grumblr. With Grumblr you can choose to post text, links, chat logs, audio and video files and also upload photos to your Tumblr blog right from your Ubuntu desktop.
The installation process of Grumblr is not the familiar way. First you need to install some dependencies to your system by opening your terminal and typing:
This will install every dependency you need and then you’ll need to install Grumblr and add it to your menus by opening the terminal and entering the following command:
Below is a screen shot of the application:
