Hi everyone!
Anybody who can help?
If you want to update your Zune software to the latest version 2.5.447.0 and we are having problems in the installation or updating of the software then try to turn on your Windows Firewall.
If you choose to turn on other firewalls it is not going to help. So, if you want to software a media player you have to turn on built-in Windows firewall.
Microsoft said that if you want to update your Zune media player, it is essential to enable a completely separate version of the operating system you are running.
There are many issues in this and Microsoft should have come up with a better solution by now since this requirement of turning on the firewall for Zune software update has been there for quite a few releases.
The update does not say that a necessary component is missing neither does it tell you what to do to complete installing. It does not do either of these rather it gives you a strange error message leaving you with the only option to search the internet.
Installation Failed
Setup must stop beceuse the required package Zune failed to install.
DWXAPP Rollback failed with error 0x2
Error code: 0x80070643
http://go.microsofLcom/fwlink/?LinkID=101253
Close
Updating Zune software to its latest version
I have read your problem and the best solution for your problem which I will recommend to you is this one. I have mentioned the following requirements for your zune software.
• You will need an A1 gigahertz (GHz) or maybe a faster 32-bit (x86) or 64-bit (x64) processor
• You will need a 1 gigabyte (GB) RAM (32-bit) or better if 2 GB RAM (64-bit)
• A fast broadband Internet connection
A wi-fi network is needed to wirelessly sync your Zune device to your computer.
*Please not that the Zune software doesn’t work on earlier versions of Windows other than Windows XP SP3. Download Windows XP SP3.
I am sure that you have a windows version problem.
Hope so you will get the solution from my suggestion.
Good luck for your future working.
Thanks
If you want to install Zune software but you keep getting an error, check the system requirements again and verify that your computer meets those requirements. Download Zune Software 4.8.2345.0 on FileHippo. It supports Windows XP Service Pack 3, Windows Vista Service Pack 2, Windows 7, and Windows 8.x. Zune is a discontinued media management application designed for Microsoft Windows.
It works as a full media player application that includes a library, an interface for the Zune Marketplace, and can also function as a media streaming server. Zune software was discontinued on October 16, 2012 and replaced with the Windows Phone App.
