Updation Of Windows Gives Out 80244010 Error
Give points on the 80244010 error? What is the cause of the error code, and explain the methods to overcome this error message?
The Error Code 80244010 is a Windows 10 activation error that occurs when the system upgrades from older Windows to Windows 10. It is not a critical system error that affects the ability to install or activate the operating system. Some ways to resolve the error code are as follows:
Remove files from the Download folder.
Go to the directed location C:\Windows\SoftwareDistribution\Download and run the following command:
net stop wuauserv
Now, rename the folder of software distribution to old, then restart the Windows update service by running the following command:
net start wuauserv
Now, try to upgrade the system again.
